few LS1 motor build questions...
OK. I just burnt a piston up real bad. since i am a lil short on funding my plan is to get a big beefy short block goin for now and throw heads, intake, and a gigantic cam in in the winter. I am shooting for 600 rwhp on pump gas.
Now i know some of these might be newbie questions, but i do need a lil help here.
1. I want to rev the **** out of this motor...I was thinkin an SLP 402 rotating assembly or even just a forged 347. can that set up put up with a ton of boost/HP and seeing 7000 or 8000 rpm's at the track?
2. What do you high boost/horsepower guys use for headgaskets?
3. are head studs needed for this type of aplication or will ARP bolts do?
If you guys have any info/comments/suggestions on an alternate engine size or anything i have forgoten i would greatly appreciate it.
Thanks again,
Jim
Thanks again,
Jim
Just say no to SLP.... There are plenty of good sponsors who can build you a nice short block for the same price. Get you a nice turbo, a 347, AFR castings ported by TEA with a forced induction nitrous port, cometic gaskets, and head studs. It'll be hard to lift a head with that set-up. That's what I run on my car.
I'm planning on maxing out my d1sc or running an *** load of boost. can you pull a head off in the car with head studs?
anyone have any suggestions on rods/pistons/crank that can handle like 650-700 hp on race and 600 on pump?
Call the guys at East Side Performance.They are doing a lot of superchargers lately.I have had tuning done from there myself. They are a bunch of good guys in my opinion.
SSU'S Vice Mod
Forced Induction aspects...either turbo or blower, make sure you get the compression ratio right for it. I wouldn't go much higher than 9.5:1 but 8.5:1 or 9:1 is better, which means until you get that, you might be wishing for the higher compression. Fuel systems with FI are a must! Tuning is a MUST! 600 RWHP isn't a problem on boost, but probably no need to spin the motor to 8000 RPM on boost, even on a 347. Stock crank should be ok for your needs, so good rods, bearings, floated pins and pistons, proper gaskets, a decent hydro roller and no need to probably turn more than 7200~7500 (if that really). Make your way over there, and look through the threads...read the stickys at the top of the forum, and then quest away!
