Exactly how to break in Spec Stage 3
Alright guys i just got my Spec stag 3 installed with the spec flywheel, EXACTLY how should i go about driving it. right now it chatters like a ****, but i figured with it being brand new it will do this, can anyone give me any advice, i tried searching and couldnt find anything soo..thanks guys
My last spec I went with the 500 mile brake in and it worked out great, I would highly recomend going easy on it for the 400-500 miles. As i got closer to the end of it I was a little harder on it as miles incresed. It dose suck but I think this is why I have not had any problems. Have to replace now due to excessive jump in horsepower and stg II underated.
Originally Posted by 01_SuperSlow
It doesn't really matter how you break in your Spec clutch.
It'll be junk sooner than you think anyway
i really hope i am breaking it in right. just normal driving no beating on it, bever letting it get above 3000rpms, no hard shifting or anything till after 600-700 miles
It depends on the installation. everyone that whines about theirs chattering, etc. I would check the installer first before blaming spec. I've never had a 3 X-Pad that chattered that left my shop. Besides a very slight bit of chatter for the first 400 miles. Just vary your RPMs dont beat the crap out of it. We have put in SPEC's and ran them on the dyno right after, and these clutches are still going strong. However I would recommend a break-in period of 400-500 miles.
I bought my S3 from a ls1tech member, and the alum FW from LG Motorsports. They told me proper break in was go out and launch it easy a couple of times, then launch it hard a couple of times and let it cool, and your done!
I did that and havent had any problems yet. And the shaking of the shift lever when taking off in 1st did get a lot less after about 500 miles, now it barely does it at all.
I asked them if they had any problems with S3 clutches and they only had good things to say.
Im happy with mine it took me from an 8.7(stock slipping) to an 8.3
Most of the time on the new units we'll glaze over the PP a bit that really helps. There is also another trick that really helps but that is why I guarantee every clutch I install here not to have a problem.
As the others said; drive easy for 500-600 miles. Try doing lots of stop and going type driving. Highway driving really doesn’t help.
My chattered a bit at first, but it smoothed out after about 1000 miles. I’ve got about 10,000 miles and lots of ¼ mile passes on it and I haven’t had any problems at all.
240M3: Not exactly. We have tried a combination of a few different things and now we have it down to a science. So much that I will warranty any SPEC 3 bought and installed at my facility no questions asked if it sucks we'll replace it!
