01 GM Z06 Wheels
01 GM Z06 Wheels
Do 17x9.5 and 18x10.5 01 GM Z06 wheels bolt onto a 2000 Z28 with out rubbing or offset/backspacing issues? If I just took the wheels/tires to tire kingdom would they know how to make it work?
they'll fit without any problem if you lift up the car from the axle(differential). If you don't lift it from the center the rear bump stop will get in the way. A 5/16'' spacer gives you enough clearance to put the wheels without having to lift as mentioned above, but its a wise choice to upgrade to longer wheel studs. If interested I have two 5/16'' spacers for 25 dlls shipped. Check out my Cardomain site (link below) for pics of my car with OEM Z06 wheels with 2/16'' GM spacers.
