Racetronix Pump, only 20pis at Rail
Racetronix Pump, only 20psi at Rail
Its taken me a while to figure out why my car wasn't running right after the heads/cam & 12 bolt swap. I also upgraded to a Racetronix pump while the rear end was out.
Tonight I decided Id check the pressure at the rail, here is what I found.
Key & Motor Off - 0 psi
Key On & Motor Off - 0 psi
Motor On (Idle) - 20 psi
Motor On (2000rpm) - 20 psi
Does anyone know what the problem could be from these symptoms?
I just installed one as well, no problems. I also replaced the filter at the same time. Try a filter and if not that it could be the feed line within the tank. Only the one end, other end comes with clamp installed. Check lines off the top of the tank make sure they are not kinked as well.
Did you clean out the tank?
First thing I did last night was swap the fuel filter, no change. I am going to check the lines tonight but I am pretty sure that isn't the problem. Looks like I am going to be pulling the tank again. I agree with you that it sounds like the hose inside the pump is either not on all the way or torn.
Does anyone know a good replacement for that hose if it is torn?
I used regular fuel line for mine.
If your tank is almost empty, have a friend turn on the key while you keep an ear near the gas tank. You'll be able to hear the gas splashing in there if it's leaking.
Sounds like one of three things. I would say the pump is to low and filter is riding the bottom of the tank, a line is loose or the pump itself is bad. Is the pump priming when you turn the key on?
LS1TECH Sponsor
How much fuel was in the tank when you first ran the pump?
Even a totally baffed pump should be able to build enough pressure at idle. Sounds like something was not connected properly in the tank?
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
>WEB SITE<
Originally Posted by Racetronix
Did you flush the tank before installing the new pump?
LS1TECH Sponsor
I replaced the hose & the pump with no change. Could this be a regulator issue?
__________________
>WEB SITE<
>WEB SITE<
Yes it could be.
