just took my heads off ??? (techs help)
Old 05-16-2005, 01:24 AM
bmfcamaro's Avatar
Default just took my heads off ??? (techs help)
my exaust valves are all white. and there is whites buildup on my spark plugs. what causes this?? what should i look for??
Old 05-16-2005, 03:04 AM
Ryguy's Avatar
your engine is running lean
Old 05-16-2005, 03:29 AM
Restricted User
CAT3's Avatar
Looks lean to me too. Have you used a WB on it? Whats your AFR like?
Old 05-16-2005, 09:53 AM
bmfcamaro's Avatar
after i put the heads on i will be using my new wideband. can i reuse the same plugs. they are not very old. also what do i use to clean the carbon buildup on the pistons.
Old 05-16-2005, 09:56 AM
jdoyle's Avatar
a friend used a dremel with some brass brushes to clean the buildup on his pistons.
Old 05-16-2005, 03:01 PM
bmfcamaro's Avatar
on my passenger side , the 15mm bolt hole on the far back above piston has oil in it WTF???? is this bad????????????
