rebuilding my 10 bolt??
my rear just clunked real loud after one pass at the local track.... now when i sit there idling with the windows up you hear some noises coming from the rear.... if i drive in a circle you hear the sucker just clunking around.... would a master install kit and just the ring and pinion gears fix this problem?? or am i gonna need axles and what not... dont plan on getting that 12 bolt anytime soon
You better have someone put it up on a lift, pull the rear cover, and evaluate what is broken, or loose inside the rear, preferably someone who is familiar w/the 7.5" 10 bolt.... WJ
Originally Posted by jessedale98
How much
200$ is all.. Ready to bolt in just changed fluid and before I put it away last fall. This year I put my 12 bolt in before I even started it. 38,000 miles on it. Perfect cond.
