Rear End Leak
Rear End Leak
My past two camaros have had juicy rear ends from day one pretty much. Is this normal for our cars or do i just have bad luck. They don't leak bad they are just juicy all the time. Should I be worried or is it ok??
Where is it leaking from?
If you run a search you'll see that the pinion seals are very poor in these vehicles.
I had to replace my pinion seal and a carrier bearing this weekend. My friend suffered from the same "leaky" differential. He's replaced the seal on his 3 times already.
