A New Noise
Old 05-16-2005, 10:08 PM
Ed Blown Vert's Avatar
Unhappy A New Noise
Well, after the 1/8 mile track. Starting hearing another noise. Idle is a bit rough. But runs strong.
Knock Any ideas?
Old 05-16-2005, 10:46 PM
LSONE's Avatar
sounds like its time to pull the valve covers and check things out, shouldnt take too long.
Old 05-16-2005, 11:05 PM
I plan on it, just trying to figure out what it is.
Old 05-17-2005, 10:05 AM
Bad30th's Avatar
I heard this noise in person on Sunday, it's not as hollow sounding as bottom-end rod knock I've heard before (spun main bearing). ...although I've never heard anything make this specific noise before...
We're pretty sure it's not the crank pulley/bolt as we verified it was pretty tight...
Things I just though of - how's your oil pressure ? Any fluctuation in oil pressure when the noise happens ? Any metal on your oil drain plug ?
I'd definately look at/verify the top end first Ed...
Rob (Bad30th)
Old 05-17-2005, 10:52 AM
Yep, I don't think it was the crank bolt. But I will double check it again.
Oil Pressure is fine. Its actually a bit higher since the install.
I will be pulling the valve covers off tonight.
I am wondering if it could be lifters....
Old 05-17-2005, 10:45 PM
The valvetrain looks fine. So I am guessing it still may be the crank pulley.
Old 05-18-2005, 01:07 AM
strokedls1's Avatar
Didn't sound like anything specific. I would check some of the plugs to see how they are running. Check for misfires on the computer also to try to narrow it down.
Old 05-18-2005, 02:19 AM
Z-286speed's Avatar
I am just throwing this out there, cam bearings?
Old 05-18-2005, 08:28 AM
No misfires. Plugs look fine.
Old 05-18-2005, 02:36 PM
strokedls1's Avatar
That top right one #7 I assume looks like it got a little hotter than the rest. What is all the dirt on that plug? How is the coolant level in the radiator?
Old 05-18-2005, 02:58 PM
Not sure what the dirt is, but looks green in color. I am losing coolant. But I think that was caused by a leaky thermostat housing.
