So who all has the famous piston slap?
Old 05-16-2005, 10:43 PM
RedZoutlaw's Avatar
Default So who all has the famous piston slap?
Just wondering how many on the site have piston slap, and how many miles on the engine with those that do.
Old 05-16-2005, 11:00 PM
tbojbob's Avatar
Well, even though that's kind of a personal question.... I have the stereotypical textbook case of "piston slap"
But.... once warmed up it's gone!
Old 05-16-2005, 11:06 PM
Bad Seller Alert
getlifted's Avatar
I am about to buy a used motor and the seller says it has piston slap but the motor is fine. What will piston slap do to the motor? Is it bad?
Old 05-17-2005, 12:45 AM
Elite_Hot_Rod's Avatar
My 99 Z slaps like crazy when it's cold, goes away after it warms up alittle.
Old 05-17-2005, 12:48 AM
Phllppric's Avatar
mine is a continuous, or so i think have not paid that much attention to it after i hit the road
Old 05-17-2005, 01:30 AM
35th SS's Avatar
use to have it on the 35th when it was stock internals.after I installed my h/c it went away.
Old 05-17-2005, 02:41 AM
RTCamaroSS's Avatar
I cant hear the piston slap over the lopey cam...
Old 05-17-2005, 08:20 AM
BottleRocket's Avatar
none for me (yet). hopefully i wont encounter any since heads/cam are going on this winter
Old 05-17-2005, 08:28 AM
-Q-
-Q-'s Avatar
I have it, only when cold. I have heard very few LS1s that DIDN'T have at least some slap.
Old 05-17-2005, 08:33 AM
1 SIC Z's Avatar
Mine is only on startup and seems to go away once it warms up. I have 5300 on the clock and it is getting more noticeable on startup....
John
Old 05-27-2005, 09:23 PM
rushman's Avatar
Late entry. Mine slaps pretty much all the time at idle. Once its good and warm (like 30 minutes of running you can still hear it but its faint. Sounds goes away when you get above 2k rpms, but its still anoying at idle. The car has always done it too.
Old 05-28-2005, 04:22 PM
SOM98TA's Avatar
I dont have it.. never ran into it???
Old 05-28-2005, 05:05 PM
RedZoutlaw's Avatar
You probably just dont hear it.
Old 05-28-2005, 07:07 PM
2001CamaroGuy's Avatar
I "had" pistons slap from the day the car came off the lot (5 miles).........it would be come "less noticeable" when hot but was still there...........I finally chunked off/melted the pistons at 50K miles which pretty much ended "that" problem.....
my forged 388 does not slap new as bad as the stocker did (very little cold/none hot)....
Old 05-28-2005, 09:03 PM
TrickyTransAm's Avatar
In my opinion, yes. Too much clearance can wear out the cylinder walls and chop up a piston head if severe enough.
Hardcore engine machinists- correct me if I am wrong.
If its a decent price, Id grab it, and check all your clearances, etc. Possibly put in a new set of pistons, after a fresh .010 overbore or hone to get everything to seat snugly.
At least that way you know what you have into the motor, what condition the block will be, and you can rest easy when cranking High R's.
C
Old 05-29-2005, 10:29 AM
Phil'sC5vette's Avatar
I fixed mine with cam, headers, and louder exhaust
