idle drops when moving a few mph, can i stop it from happening?
Old 05-17-2005, 12:44 AM
single digit dreamer
parish8's Avatar
Default idle drops when moving a few mph, can i stop it from happening?
i am running megasquirt for my fueling and efilive flashscan for everything else. when i put it in gear and start to move once i get up to maybe 2mph the idle will drop. this isn't much of a problem most of the time but when i go to back out of the garage and dont have my foot on the gas once i reash 2mph it will die. if i keep my foot on the brake and back up slowly the idle will stay at ~900.
also when i pull up to a light the idle is lower than i would like but once i get stoped it comes up to where it should be. is there a table or chart for anything like this. maybe some kind of decell throttle closing?
Old 05-17-2005, 01:27 AM
SmokingWS6's Avatar
Correct, it has to do with idle/moving throttle transition. However I don't have any Electronic throttle expirence so I'm not sure how to help you out.
See if there's any idle transition tables you can mess around with.
