Radiator hose sucked close....
And when putting water in the radiator it is spitting it out like it has a blow head gasket.
Anyone have any ideas whether or not its a blown head gasket for sure? Ive never seen a radiator hose collapse because of one that is why this is so puzzling. Id rather not tear the heads off the motor and that not be the issue. Its a friends car im trying to figure out.
Any help is appreciated.
Mike
Mike
Might be sucking air in where a hose clamps on? If the head gasket was blown you would have white smoke out the tailpipes and water in the oil, you may want to drain the oil and see if any water is in it. Check the hoses that are the return for the radiator, since that side would have a sucking affect.
Anybody else have any good input?
Mike
Originally Posted by flippincamaro
mine did that i freeaked as well but it was low and had an air pocket in itgood luck
Ill see what I can get it to do right now. Thanks
Mike
