Do cams ever go bad?
prob a stupid question but you never hear of a stock cam ever going bad or antyhing, but when people sell cams they say they are in good shape and low miles....i guess my question is if cams can go bad what are the reasons for it and how long should they last?
Exactly, hydralic roller lifters aren't as likely to fail and wear alot less than the older flat tappet hydralic or solid lifter cams. Bearing failure is the most common failure stemming from low oil pressure or such. Also a fubared lifter or lifter guide will take out a cam.
Originally Posted by 777
i suppose a cam can wear over time...but we are talking a lot of time...it rubs against the pushrods...
Originally Posted by NastyNate
I'm gonna let this slide seeing how your from Ocala.... But for future reference the cam is never supposed to touch the pushrods.
Take it easy he was just suggesting
Tech Addict
Originally Posted by WS6FirebirdTA00
what supports the large circular parts on the cam? the engine block with an oil film or is there something else?
Tech Addict
damn how do they get those damn things in there?? kinda scary to think what could happen after the cam install, although, they should only come out if ou force the cam in there right??
theoretically your cam and crankshaft are floating on a very thin lining of oil when the car is running. This is why the hardest part on your engine is starting it because the cam and crankshaft have no oil inbetween themselves and the bearings, which causes wear untill oil pressure flies up and gets in there.
