Mcloed clutch question
I have Mcloed Kevlar/Organic clutch with steel flywheel and adjustable master slave. Its been working great when I had 390rwhp for along time (Almost 2 years and 4-6K miles), but when I installed the blower the Mcloed just couldn’t handle sticky tires, 3900lbs and 550rwhp launches. The strange thing is the Mcloed is working fine on the streets now when I get wheel spin. It is not slipping when I load the clutch in 6th gear full throttle. I guess it’s just not made to withstand such power and weight on sticky tires. So I just bought the Textrila OZ700 and I was wondering if the Mcloed can be sent to get maintained so I can sell it.
So my question is.... Will Mcloed perform maintenance or check up on a clutch that has been used for almost 2 years and 4-6K miles? And how much would they charge to do a check up on the clutch kit before I sell it?
Im sure the flywheel, pressure plate and master are in great shape, but I think they might need to check on the clutch disc it self to make sure there are enough material on it.
Anyone know the answer?
Originally Posted by TAGOES11S
Yes, just call them. You'll basically get equivelant to a brand new clutch back for a fraction of the price.
The prices are as follow:
$80 for a new disc.
$180 for a new pressure plate if needed.
and $25 for resurfacing the flywheel.
The sweet thing is that they give full warranty on the clutch kit.
Originally Posted by ls2 bait
hmmmm maybe ill send mine in--thats alot cheaper than a new one. how much in labor or is that included?
