Would TR6 plugs help...
I'm still fighting some low TPS surge issues. Feels like I get bucking in the low gears, even up at 2400 rpm. There's no audible knock and acceleration is fine; it is just steady low speed driving that is a problem. Pulling some timing and leaning the VE has helped a bit. My cam is not that big (0 overlap at .05; same as 224/224 112). I'm wondering with the switch to higher compression if I should try a colder plug. Compression ratio is in the high 10.X range. I don't have a source of 100 octane gas to experiment with.
LS1 Tech Administrator
Joel,
I've found that nailing the VE tables helps the most. Once I got all my s-trims close to 0%, I then had to re-scale my MAF (from 4000 Hertz and lower) to get my MAF readings to agree with my s-trims. A lot of people forget to rescale the MAF once they do a good VE table tune.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
