Nx/fjo Tps?????
Nx/fjo Tps?????
ok i'm kinda confused with the directions so i want to verify with anyone that has theirs installed. can you use the window switch's or is that ONLY with the progressive controler? i want to use the window switch included but i dont know if i need the controller to hook into the yellow or orange wire or if i can tap a relay in one of those and control my noids. thanks for any help
Closed ex-Sponsor Account
The controller is the window switches. The yellow and orange wires controll your nitrous relays. Hook them to your relay low amp ground side pin 85 on the relay. Pin 86 goes to your arming switch.
Ricky
Ricky
ok well after i thought about it more and reading your guy's response i think i understand now. but one more thing if i had the silinoid driver that only controls the pulse to the noid's plus i have to x the box on the software right?
oh and jermey that nuber cameup as a fax number
You have to tell the controll box what mode its in. Once you check the progressive box then another window will pop up giving you the time ramp window. This is the progressive side of things. You also still set your windows to work in.
Ricky
Ricky
