Spec II or III?
Spec II or III?
I currently have around 380-400 hp, but will be getting to the 500-550hp range very soon. Which clutch is for me? I have been told the spec stage 3 is hard to daily drive with. Is the II the same thing?
David
David
I'd say go with the SPEC 3. From what I've read and what's been recommended to me the SPEC 2 might be OK for what you've got right now, but once you make that jump in power the clutch probably won't hold.
I've had 3 spec III's and only one worked. I put down 527/605 to the wheels at the time. The clutches eaither work or they flat out don't. I would'nt mess with a spec II if you are going to be puttin down 500-550 like you said. Spec III's drive like a stock clutch accept a little chatter. My girlfriend, who knows nothing about cars, didn't know the difference between the stock clutch and the spec III. If you go spec III, you must, I repeat, MUST break it in for at least 500 miles. If you don't, you WILL be replacing it.
personally i would not get a spec i just installed mine a month ago stage 2 nice 750 break in period the car has a HORRIBLE rotational vibration i am going to remove it this week and throw that piece of JUNK do yourself a favor buy a name brand clutch don't waste you time and money like i did
