Pushrods and ticking and coolant crossover for head
Old 05-20-2005, 10:56 PM
flippincamaro's Avatar
Default Pushrods and ticking and coolant crossover for head
Okay I have a ls1 5.7 with 5.3 heads milled .020 comp r lifters. F1 cam .591 .569 on a 112 the head gaskets are the stock ones from the local orielys fel-pro gaskets. Stock bottom end. Stock valves in the 5.3s but a good valve job done. Also i am running 7.4 comp pushrods. I think they might be to long cause if cruising for a few minutes at about 50mph i start to hear a really loud ticking coming from the engine but wheni stop for a few seconds and start going again it clears up for a lil bit. Has to be either the pushrods too long or rockers are messing up but they look fine or my new $200 comp lifters suck.thanks guys for all the help you have been giving me. Also my radiator is leaking but i have a new in the garage but it doesnt have the line for the top of the radiator for the head return line. Can i just cap that off at the heads but still have it crossover to each head so it still flows. I noticed my dads 5.3 truck doesnt have this from factory. What do you guys think of all this.
__________________
Old 05-20-2005, 11:01 PM
ss rally red's Avatar
Depending on the base circle size of the cam different lenght pushrods might be in order.
Old 05-20-2005, 11:06 PM
I am not that great at this cam stuff what is the base size of the cam. Where would i find this info at? thanks
Old 05-20-2005, 11:08 PM
First off check with your cam manufactor
Old 05-20-2005, 11:18 PM
I will ask the guy i bought it from if he knows it is a guy on here.
Old 05-21-2005, 12:50 AM
ATTI2D's Avatar
Pull the pushrods and check to see if you have a bent one
Old 05-21-2005, 07:32 AM
02Reaper's Avatar
If you have Comp R lifters like you state and 7.4" pushrods, you probably have way too much preload on those lifters from what comp states.
Old 05-21-2005, 08:43 AM
98 Silver Bullet's Avatar
I agree. I think with the stock set-up you get around .040-.060" of preload and that is with a stock pushrod which is 7.385". Most aftermarket cams have a .030" smaller base circle. If I did the math correctly and if you did not shim the rockers it calculates out that you are running around .035" of preload. Comp recommends .002-.004" of preload and this is checked on a warm engine.
Old 05-21-2005, 10:42 AM
Damn so i should need the 7.35 instead right? Or what size should i get? Dont have a legnth checker and dont know how to do it. What about the crossover tube for the heads? But if i have that much preload then wouldnt i need a much shorter pushrod instead thanks guys
Old 05-21-2005, 11:17 AM
02Reaper's Avatar
You really need a pushrod length checker and a dial indicator gauge to check your preload. If you have over 1/8 of a turn after zero lash to 22 ft/lbs I would say you have too much preload.
Old 05-21-2005, 10:53 PM
Great thanks guys i will check all this out
