when seating the pulley, is it flush with crank?
i got my problems 1/2 way figured out, trying to reseat the pulley right now. i have .145 inches left until it is flush with the crank shaft front snout but the pulley will not budge any more past that point. is this how it is suppose to be?? or is it suppose to be all the way flush with the front of the crank? common sense tells me i dont want it flush or else there might not be any pressure holding the pulley on to the crank if the bolt is touching the crank. let me know guys so i cna figure out what i have to do from here, thanks
ok cool so the hard part i stopped at means its back up against the back of the crank and that little gap is normal now?? i just wanted to make sure it wasnt help up before i torqued the old one and installed the new one, thanks for you help man, its really appreciated
