A/C on motor runs crappy!
Old 05-22-2005, 08:09 PM
kodiak's Avatar
Question A/C on motor runs crappy!
Hope someone can help ! When I engage a/c on and come to a stop light the motor wants to rev up back and forth from normal to abnormal rpm ! Just like
someone is pushing the pedal on and off ! What is this ?
Thanks
Old 05-22-2005, 08:16 PM
Cal
Cal's Avatar
Mine started doing that after I installed a cam. My solution was to remove the A/C!
Old 05-22-2005, 08:17 PM
ss rally red's Avatar
Tuning issue!!
Old 05-22-2005, 09:02 PM
00Formula's Avatar
That sounds pretty normal to me.........most every car that i have seen does this after a cam installation.
Old 05-23-2005, 05:43 AM
ArcticZ28's Avatar
Take the A/C belt off for the time being or don't run the A/C. Mine will remain off until I get a tune.
Old 05-23-2005, 12:41 PM
Quickin's Avatar
Thanks
Idle relearn. In this order right in a row.
5 minutes at idle in "drive" with the emergency brake "on" to hold the car in position, OR block the tires with chalks
5 minutes with A/C on full blast and in "max" with the emergency brake "on" to hold the car in position, OR block the tires with chalks
5 minutes at idle in "park"
It made mine perfect again when I had surging problems awhile ago.
