Another DOES THIS FIT Thread
Old 05-23-2005, 07:02 PM
DopdBrd's Avatar
Default Another DOES THIS FIT Thread
OK here is the deal, I have some American Racing Rebels in a 17x9 with 275/40/17 Nitto NT555 on them now. I got two more wheels cheap and want to put drag radials on them. The tires in the rear now rub whenever the rear end flexes and it has cut my tire a tiny bit.
Now, if i rolled my fender lips, would 315/35/17 nitto drags fit on the rear rims??? Any input would be GREATLY appreciated. Thanks
Old 05-23-2005, 07:16 PM
tripps's Avatar
https://ls1tech.com/forums/wheels-tires/120716-wheels-tires-everything-you-should-need-know-here-must-read.html
Old 05-23-2005, 09:41 PM
Xsta Z 28's Avatar
Depending on your offset, all should be good once you roll the quarter lip . . .
Old 05-24-2005, 11:32 AM
DopdBrd's Avatar
The Offset Is The Same As The Other Wheels +24mm. Right Now The Rear Tires Hit The Fender Lip When I Go Over A Really Big Bump Or Come Down A Steep Incline Because The Rear Axle Flexes And The Tires Goes Up Into The Fender Well.
