just got my car back with spec st3. clutch feels light as air,is this normal?
i only have 5miles on it,but when i push the clutch it feels real light,way lighter then stock. i have the spec st3,new slave and mcleod adj master w/drill mod. should the clutch pedle be this light? thanks, mike c.
Mine is the same way. Its been soft since day one... never got softer or harder. It grips fine but more towards the top of the pedal swing. No slipping what-so-ever. I am around 1500 miles into it and i started to have a problem shifting into 1st every great once in a while. EPP said they will fix it free since they installed it, but i think it may just need bled a little more.
Also to get it in 1st when it does happen, I just have to pump the clutch once or twice and it will go right in.
At the same time of the clutch install we did a new updated hyrdraulics system (slave and master) along with a Viper T56 and the Spec3
Originally Posted by Mike K.
I have felt a couple of 3's, they feel to me just a tad harder than stock,
LS1TECH Sponsor
the stage 3 with stock hydrolics will feel soft like stock . let the hydrolics do the work not your leg
if youve ever felt a king cobra in a mustang you will really appreciate yours after
