01 stock wheels not fitting on 96??
Just trying to help a guy out... Sold him my stock chrome 01 wheels, and he says they wont fit on the rear of his 96.............
any ideas?
any ideas?
i had that issue on a customers car once. i believe there was a lip on the center of the wheel, we grinded the lip off and they fit normally after that. the hub on the rear was the same size as that lip
Yep just grind a little on the hub opening on the wheels untill it slips on easy. Doesn't take much work at all.
I had to do the same thing with my car on my old wheels.
Ok I have the same problem with a twist!!! I actually got my stock 02 wheels on my 93 no problem. But now I cant get them off because they are stuck on the lip. Any suggestions on how to get these off? thanks
I just used a 3 inch 80 grit "flap wheel" on the WS6 rims I bought for my 94 TA. Put it on a cordless drill, and a minute later, voila, the rims went on. I just took barely enough off to get the rim to go on and fit the axle snug.
I would drive around with them on untill the wheels warmed up. Then spray some penitrating oil and get a rubber mallet and work around the tire untill it pops off.
