Max RPM
Max RPM
What the maximom RPM i can reving if i have cam and PR and leftrs and sprins and taiming chine ?
I have vortech supercharger unit whare i can get the instoltion kit for LS1 (GTO) Pontiac ?
[QUOTE=hold]What the maximom RPM i can reving if i have cam and PR and leftrs and sprins and taiming chine ?
https://ls1tech.com/forums/generation-iii-internal-engine/326432-redline.html
Anyway, strap the car on to a dyno and find out where it makes its power. Assuming you have all the necessary equipment, you should be able to spin pretty high. The dyno will catch valvefloat, if your setup's power dosnt fall off well before that. One thing to watch out for is that with forced induction AND high revs, your rod bolts will be crying to mommy. Might want to change them out too.
-T
