Broke my T-56 tailhousing....Need lots of help!
Broke my T-56 tailhousing....Need lots of help! (pics)
Well I broke my T-56 tailhousing this weekend. I was slamming first gear from a slight roll. My tires where spinning just fine. I slammed second and that's when my heart stopped. I heard a loud snap and it was followed by the sound of my drive shaft slapping the bottom of my car as I came to a stop. I also noticed that my shifter was not connected to anything because I could move it in one big circle. The link to the gallery shows it all as my friend and I removed my tranny. You can see the output shaft is snapped, the shifter is bent, and the tailhousing is F***ed. I was hoping that someone could help me out. I don't have lots of cash. I would like to know if I can buy just the tailhousing, where, and how much. I also would like to rebiuld my tranny with better synchos, shift forks, and so on. I'll need to get an output shaft and I noticed that my input shaft is a little worn out do to a bad pilot bushing (I am now using a bearing that came with the spec stage IV kit). Where can I get these things and how much do you think a tranny shop will charge for the labor? I was also wondering if my drive shaft is still good if I pull what's left of my output shaft out. I noticed that it had a few scraches on it. Will this cause a vibation, or make it too weak? My car has had a vibration in it that's really bad around 75mph on the highway that I've never been able to figure out. Any thoughts on what that might be are welcome. Thanks everyone.
Click here to view pictures of the damage
The yoke on the propshaft is not salvagable. I would not spend too much money on that trans either. If it needs a rebuild you will have to spend those $ plus the broken parts I think you are in replacement box range. BTW this is secondary damage what else was going on in the driveline? Did you have vibration (awhile) before this? Was the rear mount damaged?
I just have a few bolton's. 4.10's, JBA headers, chip, ect. I'm not running a locker eather. I did have the vibration awhile before this but it was only noticable at hight speeds. The rear mound was fine and didn't find any other damage under the car. squintz palladoris you think that the output shaft could have been the cause of the vibration. Is it likely to twist the output shaft with street tires and 321RWHP, 331RWTQ?
Originally Posted by 777
What's the deal for real. Just for a basic rebuild and new hydraulics I have been quoted like 2000-2500.
again, whats the deal with the damage inside the bellhousing?
The bellhousing is another mistery of mine. One day a came to a fast stop and heard something rattle around in my tranny like rocks. It happened for about three days and before I could get it on the lift to look inside it stopped. I pulled out my tranny to replace the clutch that was slipping and found all of this damage inside. funny thing is I had alot of people look at it and no one can figure out what it was. My old setup had no missing parts at all, springs rivets, everything was still there. I don't know what the hell happened!?
Jesus.. You did that with your power level... It's all that speed shifting you did...
We have 1 or 2 Extra T-56's laying around.. We might be able to sell 1 to you, however it due for a re-build, as it runs fine but sometimes grinds 1 - 4th.. The syncro's are out... Came out of a 98 Trans Am.... It's a non Tremic, it's a Borg W. Trans..
Clint
Clint
Originally Posted by MIGHTYMOUSE
if youre speaking to me the deal is you have been getting bent over on $.. either that or you are including paying someone to remove and reinstall. This guy can obviously do that himself.
Had to use a hammer to tap the DS so that the yoke would slide into the tranny further to get it away from the pinion yoke. Then had to tapp it to get it back out.
It had been vibrating eversince it was a bolton car. I'm glad it never broke like yours did.
A new Mainshaft will run ya between 200 n 250. Not sure on the Shift extension housing.
I do have a Bell housing I will not be using in the future if you want to replace yours.
777 for 2 grand you can get a nice kit from G-force. It has their 9310 mainshaft with the triplecone scyncros, Billet slider keys, and a C5 gearset (required to run their mainshaft).
Brad
as far as your bellhousing goes, I had something similar happen to me a couple years ago, but i didnt hve a spec clutch, i had a hays clutch, and they used rivets to apply weights to the pressure plate when it was balanced, well, some of the rivets let loose and went through my bellhousing. look around for something like that maybe? is it possible a finger broke off the pressure plate and went through?
