Need help: Cam with H/C package is diff. than what was said in sale
Old 05-25-2005, 09:52 AM
davis80's Avatar
Default Need help: Cam with H/C package is diff. than what was said in sale
I bought a H/C package from a member here, and the cam specs are different from what he had told me in the emails about it. I've contacted him to ask him his exact setup, but I was just looking for some quick help.
Basically it's a will this cam fit. I have Patriot stage 2.5 heads as well.
Here's a pic of the cam specs on the box, no cam card.
Now, I called Comp Cams and they looked up the exact specs on the cam for me given the part number and here it goes.
It's a 242/242 with .610 lift on a 1.7 rocker. LSA is 113 with +3 ground in.
The intake opens at 11 and closes at 51. The exhaust opens at 57 and closes at 5.
Thanks for the help guys.
Old 05-25-2005, 10:30 AM
camaroz28nbm383's Avatar
Whats the part # on the cam it self
Old 05-25-2005, 10:35 AM
777's Avatar
Since when did patriot start making stg. 2.5's? And that cam is pretty big, I doubt it will fit.
Old 05-25-2005, 11:11 AM
davis80's Avatar
I'm at work right now so I'll have to get back to this later.
Old 05-25-2005, 01:26 PM
JZ'sTA's Avatar
I am gonna say the cam wont fir without flycuting.
the T rex is about as big as you can go on stock heads at 242/248 with similar lift and you dont have stock heads.
If the heads have been milled at all then you will defentially be flycuting.
What were the specs the seller gave you?
Old 05-25-2005, 01:29 PM
tim99ws6's Avatar
It is very possible the seller put the old cam in the box that his new cam came in. Just cause it came in that box doesn't nessecarily mean that's what the cam is. You'd need to crossrefrence the cam somehow, or have it cam doctored to be sure that is the cam it is.
Old 05-25-2005, 05:17 PM
mikemodano9c's Avatar
there should be an etching on the end of the cam that corresponds to the model number on the box...
Old 05-25-2005, 06:51 PM
JayLS1-327's Avatar
I agree, the only way to be 100% positive is to have the cam doctored.
Old 05-25-2005, 07:00 PM
01_SuperSlow's Avatar
My thoughts exactly.
