LS1TORQ
05-25-2005, 09:27 PM
Ok well I know this is common and I just want to check with you guys. When I shift in to third gear at 5500+ RPMS it will grind alittle bit, and when downshifting to 3rd at speeds over 50 MPH it will grind a bit. Now my dad says its the syncros but from what I have read it sounds like the slave cylinder. Keep in mind my car is a 98' (with the crappy slave cylinder GM doesn't even make anymore) with 106k. So which one is it? If it is the slave cylinder how do I go about accessing the old one to replace it? Do I have to drop the tranny? Also my clutch fluid is black could flushing the system fix alot of the grinding? Thanks Guys!!
