Anybody ever heard of CFE cylinder heads??
I first saw these for sale in the jegs catalog. they seem pretty good for how much they cost. I checked out the specs for the 350cc heads on their website and they supposably come already assembled with .880" springs which is pretty good for the cam i am looking at considering other heads just come with .750" springs. also, they flow i think the same as the AFR 357's or somewhere around it. My question is have you ever heard anything bad about these headsor anything good? Any other tips of advice would be helpful. thanks in advance.
ive heard of them for BBC's they are good heads. flow nicely even better with minor port work, they are good for a bolt on heads (uses factory intake manifold bolt pattern). but they need a big bore engine to work right 4.500'' and larger. they have great flow, expecially if you buy them direct from them they can port them for you.
Originally Posted by 69chevy
we plan on building a 540 which is good so far considering they will work with the 4.500" bore. as for the intake, we bought a tunnel ram which a nitrous set up for a big block.
it should work, ive seen a few of these sets of heads with dual carb'd sheetmetal intakes about 6' high. make sure you port the tunnel ram to the heads though.
Originally Posted by blown454ss
would those heads be to big for a 489 stroker? or do they make any smaller that would be better?
Originally Posted by 68maro
and what kind of tunnel ram did you buy and what cam carbs and CR are you planiing on running.
WOW!!!! six feet that should help with the velocity somewhat!!
6 inches
mine fit under my 5 inch cowl without a problem but i switched to a 6" for increased airflow. if you want power ditch the weiand and get a dart tunnel ram and don't even think about putting 660's on it go for for a man carb. like a dominator.
http://gallery.thevboard.com/showpic...iler%20032.jpg
it would kind of be a problem ditching the tunnel ram and carbs because it is money spent but if anything i'm sure that we could get our money back if we try to sell it. Heck maybe even more than what we paid. Hey 68maro, what size are those dominators, if they are dominators? Also, where can i check out that Dart tunnel ram you guys are talking about, what website?
i think you should go with something like this
http://www.racingjunk.com/exec/ca/vi...-manifold.html
but see what 68 camaro has to say, he deals with bbcs far more than me.
So more or less just go with almost the same setup as 68maro has. Tunnel ram with dominators on top. I'll be shopping around to see what the cheapest I can get a Dart Tunnel Ram or sheetmetal intake for along with dual dominators. After the shopping part, I need to see how much i can sell my tunnel ram setup for and then I can go from there.
