Master cylinder U bolt...
Old 05-26-2005, 01:48 AM
Michael Ozorowsky's Avatar
Default Master cylinder U bolt...
anyone have an extra one? I'm doing A4 to M6 swap and could use one. If so, would you sell it to me? Or you know where I can get one? THanks.
Old 05-26-2005, 02:30 AM
Also does anyone have pics of what the u bolt looks like? Thanks.
Old 05-26-2005, 08:47 AM
LS1TECH Sponsor
Steve Burger's Avatar
You can get them from SDPC. I have an extra but the thread ends on one side are not that great. They are about $10 from SDPC.
Old 05-26-2005, 08:58 AM
TAGOES11S's Avatar
I have a extra one. $10 shipped sounds good. PM me your address.
Old 05-26-2005, 09:23 AM
Griswold's Avatar
you don't have to use the ubolt if you don't want to. You can just use two regular bolts with lock washers and nuts. Just in case you can't get one quick enough
Old 05-26-2005, 10:42 AM
What size nuts and lockwashers would I use? Also, do I need a specific bolt? I just got a used master cylinder, and no bolts with it. THanks.
Old 05-27-2005, 11:47 AM
GETSOMZ28's Avatar
I just took my u-bolt to lowes and measured it there. The correct sized bolts are M8 x 1.25 x 40. I got some nylon nuts for piece of mind.
Old 05-27-2005, 12:00 PM
THANK you all, you guys ROCK
Old 05-27-2005, 07:17 PM
tuffluck's Avatar
have fun with the worst piece of gm engineering ever!
Old 05-27-2005, 07:20 PM
what would that be? The T56?
Old 05-27-2005, 07:47 PM
GETSOMZ28's Avatar
he probably meant the u-bolt/hydraulics. Just use the bolts I suggested and you will be fine. BTW, the T56 was/is built by Tremec/Borg Warner, not GM.
How is the swap coming along? Mine should be done as soon as I get all the little nuts and bolts together.
Old 05-28-2005, 12:59 AM
STF veteran / 10 second club
x phantom x's Avatar
ROTFL ... Definately.
After like an hour attempting to figure out how the hell that U-bolt fits back in with all the **** down there that is in the way ... I just went and got 2 bolts and some lock nuts from sears, and was done 5 minutes after I got home with them.
Much better idea.
Old 05-28-2005, 01:38 AM
Swap is going so far so good. I'm just waiting on the money for the actual transmission/bellhousing, but I should have my pedals at my door tomorrow, then after that Sunday will install pedals/hydraullics/clutch then just need to put the tranny in.
I'm also looking for a cheap pro 5.0 shifter. Hopefully a used one somewhere.
Old 05-31-2005, 10:39 AM
Hey guys, I don't want to start anything, but I paid TAgoes11S for the U bolt, back on May 26, it is now May 31. I have sent him a PM every day since I paid him, and haven't heard a reply. If you know him please ask him to email me. I am about to file a paypal complaint. Thank you.
Old 05-31-2005, 04:34 PM
Just heard back. Everything looks so far so good
