View Full Version : Best Race Fuel ??
oOoLy
05-26-2005, 10:24 AM
What is the best race fuel C16 or C14 or C12 or or ... for N/A 13.5:1 or 14.0:1 compression ?
and if i want to spray 250hp which one is better ?
Thanks
Race Car Driver
05-26-2005, 10:58 AM
Call your local VP rep for answers to these questions. Each fuel is designed for specific application. What is the best race fuel C16 or C14 or C12 or or ... for N/A 13.5:1 or 14.0:1 compression and if i want to spray 250hp which one is better ? Thanks
1fastWS6
05-26-2005, 11:32 AM
Thanks
I run Sunoco 110 in my 'bird. Its 13.5:1 N/A. I'm planning to spray a 200-250 shot and when I do will probably go to 116 oct. to be on the safe side.
oOoLy
05-27-2005, 12:46 PM
So if i run C14 in the N/A i will on the safe side ? or that will be too much ?
Pro Stock John
05-27-2005, 01:05 PM
You should go to their website and read up, but C12 is ~110L. C14 is formulated for high compression N/A (like your combo). C16 is for FI, like my combo. Some folks use C16 for motor + nitrous and some use the C19? or 21?, the nitrous fuel they have.
So plan on C14 for all motor.
oOoLy
05-27-2005, 03:58 PM
Thanks for your help ..... :)
Race Car Driver
05-27-2005, 04:24 PM
If you are running the GM PCM, ignition, cats, etc., you must run unleaded gas. In which case, VP makes a 104 octane unleaded fuel, which would handle c/r of ~13:1.
VP's C12, 14, 16, 25, etc. are leaded fuels. What is the best race fuel C16 or C14 or C12 or or ... for N/A 13.5:1 or 14.0:1 compression ?
Thanks
oOoLy
05-29-2005, 04:22 PM
So the 104 octane unleaded fuel will be good for N/A 13:1 c/r . but how about it if i want to use some nitrose ?
Race Car Driver
05-30-2005, 04:29 PM
104 octane unleaded fuel will be good for nos.So the 104 octane unleaded fuel will be good for N/A 13:1 c/r . but how about it if i want to use some nitrose ?
