383,402,408,422,427, 441???
Originally Posted by DNAST1
Can someone please explain to me whats makes a 402 a 402, 383, a 383 and so on!? Too many configurations
7 Second Club
or course with larger cubes youll need a larger cam.... a better flowing intake and TB and a good set of heads... and some large (1 7/8) headers...
one thing leads to another and strokers cost a good deal of time and money...
mainly money.... but it just takes time to pull the motor.... hone it... put it back together... wait on parts..... wait on more parts.... break something on install.... wait again.... do you see a pattern...
Originally Posted by 1CAMWNDR
389.....4.135" bore with a stock 3.322" stroke .
1. Stock block honed with a 4.00" stroker crank shaft = 383 "All Stroke".
2. Stock block honed with a 4.125" crank= 396 All Stroke.
3. Stock LS-2 block honed with a 4.00" crank= 402 cubes
4. Stock LS-2 block honed w/4.125" crank =414 cubes
5. Darton block w/4.125 bore and 4" crank = 427 cubes
6. Darton block w/4.125 bore and 4.125 crank= 441 cube
*You can change bore sizes on the Darton to make diffrent cubes.*
7.The C5-r block carries the 4.125 bore, so it is the same as the above Darton numbers.
8.6.0 block w/ 4.030 bore and 4" crank = 408 cubes
9.6.0 block w/ 4.030 bore and 4.125 crank= 422 cubes.
*Max bore on the 6.0 block is 4.060 if the block passes sonic testing*
You could also use a 4.250 stroke crank if you wanted even bigger numbers, but the rod angle starts to get bad and causes alot of side loading. You can also use stock cranks in some of the above blocks and get 387's and so forth, but these would be "All bore" motors. The all bores tend to make more peak HP, whereas the "all strokes" tend to make lots of low- end torque.
7 Second Club
Originally Posted by Beast96Z
3.622 is the stock stroke. There are many configurations to strokers for the LS-1's. We have so many diffrent blocks to work with, like the stock block, stock LS-2 block, Darton sleeved blocks, C5-R blocks, 6.0L blocks, and re-sleeved LS-2 blocks. Each block has it's limitations on bore size, so each one serves it's own purpose. Here are some diffrent configurations:
im not familiar with boring or stroking ...i can just imagine the work and time...
but can you make a 383 with just a longer crank stroke.... meaning.. not having to bore the cylinders any?
or what if you did a little boring and a little longer crank....
what would be the advantages and disadvantages to the two i mentioned?
Yes, put a 4.00 crank in it.. stock LS1 with a 4.0 crank = 383
3.905 bore + 4" stroke = 383 stroker.
If you have a brand new block that dosen't require a hone, then you can use just the stroker kit. If the block is used, it will require a hone of .005 or so. My 383 was honed to 3.905 w/a 4" crank. Stoking a motor does require new rods and pistons. Most just buy the complete kit.
7 Second Club
i dont under stand... why does it matter if its new or not determine wether it needs a bore of .005 to make a 383 stroker?
7 Second Club
If your block is new and has a factory hone on it, you will have a stock bore size of 3.898". This coupled with the 4" stroke will give you a 382. If your block is used, you need to hone it so the new piston rings will seat. When you hone, you make the bore larger which adds more volume to the cylinder, thus making it larger by 1 C.I.. Therefore the 383.
gotcha.... have to smooth things out for the used block to make the rings seal...
