pics of my spec stage 2 help where's the problem?
well here is the pics of my stage 2 after 800 miles tell me where the problem lies before i waste my money sending it back check my other post for what happenedheres the link thanks for your help
http://i3.photobucket.com/albums/y72...sureplate1.jpg
http://i3.photobucket.com/albums/y72...sureplate2.jpg
http://i3.photobucket.com/albums/y72...sureplate3.jpg
http://i3.photobucket.com/albums/y72...elsidedisc.jpg
http://i3.photobucket.com/albums/y72...esidedisc5.jpg
http://i3.photobucket.com/albums/y72.../flywheel1.jpg
http://i3.photobucket.com/albums/y72.../flywheel2.jpg
i have a 99 m6 i had a bad rotational vibration it was bad at 2000 rpm i went and installed a new slave from a 01 i had flywheel machined new throughout bearing and pilot bearing and had the spacer installed behind the slave when i called called spec they told me that i had to have the flywheel balanced to the pressure which is a bunch of crap everything is supposed to be neutrally balanced and when they machine a flywheel they take the same amount off all the way across the whole piece so it is still neutrally balanced so i do not know any more input thanks
Just for good measures you might want to pull the FW again and make sure it is sittng flat, nothing behinde it, clean mating surface. It might be some what cocked. If able put a dial indicator on it if you can and check the run out, see if it is turning ture. Can clamp a referance point to the block and place it on the FW and turn it an measure with a feeler gage as well if you dont have a dial indicator.
Good luck
well i installed a Z06 clutch clutch kit on wensday night and have been driving the car ever since but it is only thursday but anyway i have no problems with it as with the spec i had a vibration as soon as i pulled the car off jack stands
Kind of looks like the pressure plate might not have been torqued down correctly or enough, causing that one hot spot. It would cause a vibration too if you had one. It looks like it was slipping or something wasn't correct with the clutch. Not sure what that blue circle spot is on the clutch forks in the 3rd pressure plate pic, but did something come off the clutch and maybe hit there?? Did you see any extra bolts missing, or anything after you removed it?
I have a friend that had a Spec in his car and the bolts backed out a little and came loose causing the clutch to slip bad. Did you use locktite on the bolts at all? You should use some red locktite to prevent any of them coming loose, etc.
no missing bolts and everything was torqued correctly triple checked everything 52 on the pressure plate and 74 on the flywheel thats working up to those specs just wanting to know if anyone has seen this before
