Is this right?
Is this right?
I'm trying to set up to tune my VE table via STFT's (HPTuners). I've set the MAF fail frequency to 0'but have a question on disabling the LTFT's. I went into edit>engine>general selected fuel control>open and closed loop fueling but i don't see where you can disable the LTFT's. Is this the area that reads "Use Idle Proportional Fuel Tables"? I'm using version 1.4. I don't see how to disable PE mode either. Any help would be appreciated, thanks!
