How to get the speedo to work on a T-350
Old 05-27-2005, 11:43 PM
SpdfreakLS1's Avatar
Default How to get the speedo to work on a T-350
Quote from kevredz in the t-400 faq
For the speedo:
Is the VSS Sensor GM#8655291 and the Relutor ring GM#8655315 compatible with all TH350/TH400 tailhousings? or is there certain tails that which they won't fit in?
Well the answer is no to that, those part numbers are not compatable on a 350 since i just tried them, the ring is accually too big, as well as the sensor. ANyone know what does work? A friend has a 350 setup that works but he doesnt know how its done since he bought it used and cant get ahold of the seller to ask. THanks
Old 05-28-2005, 10:24 AM
jxaxsxoxn's Avatar
You need the reluctor ring off a 700R4. The VSS will work off the same trans but i'm not sure if it's electrically compatable.
In order to get it to fit you need a BOP Buick, Olds, Pontiac tailhousing with a 2" speedo hole.
A chevy th350 tail has a 3/4" hole.
