spacers for prostars
I am going to run 15" prostars on my car and I was searching on here to find out how much spacer it takes to keep from having to grind my calipers down. I know its much safer to just grind the calipers but I would still like to know how much spacer it would take?
5/16 spacers, but you need longer studs to safely run them. I only had about 4 full turns of the lugnuts on the front wheels. I ran them for 1 day then got the grinder out and got rid of the spacers. On the rear, I used 1/8 IROC spacers after grinding forever b/c I was running out of daylight to get the wheels on the car. Took them off the next day as well. But I had about 7-8 full turns on the rear lugnuts.
