cyl 6 missfire
Old 05-29-2005, 01:01 PM
SPEEDYws6's Avatar
Default cyl 6 missfire
I did the coil relocation mod last night and now I have a missfire on cyl 6. I swapped spark splugs, wire, and coil with another cylinder and it stays at 6. How can I check for voltage to the coil? I have continuity in the coil harness, but I don't know if 6 is getting battery or signal voltage.
Oh yeah, I left my test light at work and all I have here is my DVOM.
Old 05-29-2005, 02:21 PM
Adrenaline_Z's Avatar
You might have trouble getting a reading with a digital meter depending
on the sample speed.
Connect the meter just as you would the test light.
Use DC volts to measure for voltage.
Old 05-30-2005, 12:20 AM
SPEEDYws6's Avatar
I think I must have damaged the coil harness when I bundled it up to shorten it. I can't see how it would be anything else. That is the only other thing I messed with that I'm not 100% positive is not causing the problem. What are the stiff sections in the harness, almost like a fuseable link? It's too late now to go start the car and run any test, it's way too loud.
