timing table and actual timing are different
I'm a little confused, Is there something else that factors in the timing that I'm not aware of? I put my stock timing tables back in and went for a ride. Now I'm getting a max of about 23 deg at high rpm/wot. My low octane table says 19 and high octane says 28 deg. What do you guys think is going on?
Thanks
Frank
Thanks
Frank
Moderator
Check Knock Learn Factor (interpolates between
HO table @ 1.000 and LO table at 0.000), and look
at the various other spark advance / retard PIDs
including burst knock, the ECT & IAT factors and so
on. If KLF is not 1.000 then you have a history of
knock retard that's being suppressed by spark
learning.
learning.
