*Urgent* help truck won't start!
I've just finished buttoning up my cam swap, put in the new PCM, and the truck tries to start but shuts off almost immediately. I've done the PCM learning trick multiple times, but it doesn't work.
Help!!!!
Help!!!!
the pcm shuts down the injectors within 5 seconds if it does not see the aok signal from the bcm. bakerelectronix.com sells a vats bypass little box for about $25 or you can have the vats and bcm disabled by a tuner.
hope this helps,
dan
hope this helps,
dan
take your key put in in the ign. and turn to ign(not start) and leave it there till the theft light quits blinking. It usually takes 10min. This will teach the new computer the proper mv for vats.
