Direct Port!
Direct Port!
I dont know anything about Direct Port Nitrous! I see a lot of LS1's running it! Why do so many people run DP kits and can they cause backfire in the manifold at a higher risk than wet kits?
I probably shouldn't be replying to this but.... A direct port is a wet kit... and (correct me if I'm wrong) but it really takes down the chance of a backfire because it limits gas puddling in the manifold because it fires into the port, not the manifold. You get an optimized distribution of fuel and No2 between chambers.
With a direct port kit the nitrous/fuel is being shot directly into the combustion chamber. The intake plenum is not being filled up with gas so if there was a back fire there would not be all that volume of gas and nitrous to explode.
A Direct port kit is also going to be more balanced across the board. Each cylinder getting the same hit.
edit: yeah what he said....didn't mean to copy you didn't see your post
Originally Posted by 150shotWS6
Using NX piranha kit! would I still need to upgrade my stock internals running a 125 shot?
Direct Port Pro's:
1. Able to make as much power as you want
2. Able to tune each cylinder
3. Not flowing Fuel through the intake
4. Look Mean as Hell
Direct Ports Cons:
1. COST
2. To Change A/F you have to change at least 8 Jets
3. To Change Horsepower Ratings you have to change at least 16 Jets
4. Plumbing the Intake
Not Saying I dont like Direct ports, hell my motor has 2 direct ports on it
Originally Posted by BTL FED
If you are only running a 125 shot I would stick to a standard single nozzle, they work great, they are cheap, and alot easier to deal with for a nitrous beginner, if you are thinking of going over 200 then start thinking about a direct port.
Direct Port Pro's:
Direct Ports Cons:
1. COST
Direct Port Pro's:
Direct Ports Cons:
1. COST
