Launching
Launching
I've done a search but can't seem to find anything on the subject. The car is an 00 m6 with 40ish k miles. I've been reading and alot of people break their 10 bolts is it just because they launch at 3-4k rpms? So what should I launch at w/o worrying about me breaking my tranny? Also what tires should I get for my stock polished SS rims, thx,
Nitto 555r is a great street/strip tire.W/nittos I would do a controlled clutch dump.I would describe it as letting up on the clutch equal to flooring the gas pedal.I got low 1.8X 60' with this technique with a 4.10 equiped 10 bolt.It takes time to master but works great.
Well I was thinking about getting the Mickey Thompsons drag radials, those sticky? I don't have traction controll on my car so I definatly need sticky's, can you be specific like rev it up to 1.5k then dump the cluctch let it grip then floor it or something like that, thank you!!
3500-4000 rpm and just dump it hard and fast and floor it
worked great for me when i had a stock clutch and nittos
did not break anything and got mid to low 1.8s that way
hey this is how i look at it
if you are willing to run your car at the track you have to be willing to except that you might break something...plain and simple
if you want to go fast...stuff breaks but sometimes it does not
its rolling the dice when you launch hard on drag radials but like i said i did fine but i would not do it if you have a spec clutch or something simular becasue it wont be maybe i will break...you will break
so just go to the track and beat the shiz out of it
Lont time no post by controlled launch do you mean like drop the clutch slowly and let it slip a little I dont go to the track it'd be stoplight racing, lol maybe concrete maybe asphalt TTT
Can we get a how to launch sticky?
I had a similar concern/thread on another forum. I was told; roll off the clutch and onto the throttle and your rear will thank you for it. Stickys are the quickest way to kill it. That and 3500-4k clutch "DUMPS". I've never been to the track but I don't think it's a "DUMP". It seems more of a "CONTROLLED" rapid clutch engagement. If you're that nervous about it, I wouldn't think a Stud Girdle could do any harm. Kind of stifens up the rear from deflection. I understand your concern. I don't have $2000 to throw at a rear right now, either. I like smoking 2nd but I like my rear better.
