Wet shot & Fast 90MM? Maximum safe shot?
Old 05-30-2005, 12:21 PM
ForceFedC5's Avatar
Question Wet shot & Fast 90MM? Maximum safe shot?
Hello,
I've got 2 "fogger" type nozzles going in as a wet shot now. I've heard on some forums people saying that there are issues with puddling with the Fast manifolds and that's why they have direct port holes already?
Anyone have an idea what a safe shot is?
FYI, engine is forged, hi compression.
Thanks!!
Old 05-30-2005, 12:39 PM
beardWS6's Avatar
I run 150 with H/C and no problems!
Old 05-30-2005, 12:58 PM
next's Avatar
IMO I don't think you'll have any problems with puddling as long as you spray over 3000 rpms to keep up air velocity.
Old 05-30-2005, 01:14 PM
Wyckedcamaro's Avatar
oh and make sure your psi is above 900
Old 05-30-2005, 01:28 PM
Nickn20's Avatar
no problems here with a TNT wet 150 shot, that actually nets me 225 rwhp gain!
Old 05-31-2005, 08:34 PM
ForceFedC5's Avatar
Thanks for the info guys!
Sounds like I have nothing to worry about.
What about octane issues? For those of you high compression and a decent shot, do you run race gas or additives?
Old 05-31-2005, 08:51 PM
next's Avatar
Additives aren't worth the money or effort. What they are referring to is raising octane in tenths of points. So to say it raises 4 points really equal 4 tenths.
How high of compression and how big a shot? Even w/o that answer, the safest bet is always getting a wideband reading and spray at 12-1 a/f and under.
Old 05-31-2005, 08:59 PM
10 & 11 Second Club
Caveman's Avatar
Whats up Eric
Old 05-31-2005, 09:59 PM
ForceFedC5's Avatar
Compression is about 11.4 or so. I'm more or less getting worried about timing. Does the stock knock sensor give readings at full throttle? Will it retard timing on its own?
Sorry for all the questions.. I just don't want a BOOM
Old 06-01-2005, 04:49 AM
next's Avatar
Originally Posted by Caveman
Whats up Eric
Dave, what's up my brotha!
ForceFed,
If you have access to a dyno that can take wideband readings you'll get the highest comfort level and know exactly what's going on. If you can't go that route, a conservative approach would be to pull a couple of degrees of timing, mix some 100 or 104 in the tank, run off a window switch and call it a day (assuming you're running no more than a 150 shot).
