Reset Harlan Shift Light?
I need to reset my shift light since I've had heads, cam & headers installed. The lights will not flash when holding down the push buttons to confirm the change. Am I doing something wrong or does it have to be disconnected for a while to have it reset? I know the light still works when running but it is impossible to tell because of the slowness of the tach needle. If the dip swiches are set where I want them will the light come on to the desired shift point without having a confirmation flash when setting it?
Race your car!
I actually need the directions gto one of these, I found out mine is set wrong after the cam install.. I've been shifting @ 5900... not 6400 where I should have been
If you've got a set of directions to this thing, any way I could get you to pdf to email a copy to me, or a link to a place on the web that has them?
I did get my light to reset after trying again the next day.
Here is a link to the install & setting of the shift light.
http://www.installuniversity.com/ins...ht_install.htm
