Tapping the Crank?
Old 05-30-2005, 10:33 PM
K.T.'s Avatar
Default Tapping the Crank?
I've managed to somehow get a crank with stripped out bolt threads, on the main crank bolt hole. How hard will it be to tap/rethread this hole? I know its way back there, and I don't think I've seen any taps that long before...
Old 05-30-2005, 10:40 PM
sandking's Avatar
Sounds like another "too long of a bolt crank". Not sure if you can safely re-tap the crank. I would be worried when you have to torque the crank bolt at 240 ft lbs.
Old 05-30-2005, 11:12 PM
CharlieLed's Avatar
Any good machine shop can do the job for you...
Old 05-31-2005, 12:54 AM
sardog46's Avatar
I did it almost a year ago, been running strong ever since.
Had a local machine shop tap it while the motor was in the car.
