MSD window switch modified for LS1
Hi every body
Trough my search for window switch I found MSD is reasonable for my system. But what is the different between (RPM window switch modified for Ls1 & the stock one)
Thanks
Thanks
i think it's because the ls1's tach signal reads like a 4cyl so you have to modify it from an 8cyl to a 4cyl if that makes any sence.
i have one already set up for a ls1 with extra pills if you want it PM for price
Originally Posted by 97cobra
just buy the digital switch, just installed mine and works great. you just scroll through and pic the correct firing order of your car!
if your going to buy anything get the fjo/nx switch. i bought one and it's awsome. hook it up to a computer and adjust your two window switch's and tps switch. you also have a setup for a trans brake or trigger switch of some sort. best nitrous investment ever
