Pilot beang removal
I used a slide hammer w/ pilot bearing puller attachment from Autozone. I had to grind down the ears slightly on the attachment to get it to fit through the pilot bearing. You don't need to worry about the freeze plug until you're reinstalling the pilot bearing. Just make sure you stop when the pilot bearing is flush with the crank.
Originally Posted by AW794
I heard that LS1's have a freezeplug in the crank and i didnt know how to about removing the pilot bearing. Anyone have any tips? Thanks
https://ls1tech.com/forums/manual-transmission/330495-pilot-bearing-removal.html
