Holden Performance - dash & instrument transplant
seabee1678
06-01-2005, 10:45 PM
I am installing instrument panal & dash ,engine & 6 speed out of a2004 GTO into a 1986 El Cameno. Does the 2004 GTO have a Powertrain interface module ? I so do i have to use it to make the instrument panal work ?
Holden LS1 Tonner
06-05-2005, 05:29 AM
there used to be a Holden service training manual on this link http://carprogrammer.com/Z28/PCM/LS1/Holden_LS1.pdf but it stoped working a while ago , it shows a Powertrain interface module behind the lhs kick panel . Would a painless wiring harness be a way around that problem ?
http://www.painlessperformance.com/webcatalog/cat-fiharn.htm
VYSHSV8
06-06-2005, 05:14 AM
I am pretty sure it would work with a painless wiring, well at least they would know
in a manual the only thing realy would be the speedo to worry about wouldn't it.
HSV-GTS-300
06-29-2005, 03:26 PM
I got the Holden Engine Management (Holden_LS1.pdf) file here and also know where you can download it yourself.
Send me a Private Message if you want it. 3.11Mb
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
