Got my T-REX cam today?
I've been waiting on this cam sence may 12th .Thunder raceing just got a new batch in . My quiston is the cam suppost to be 242/248-608/612-110 the T-Rex that I got is a 243.3/249.2-609/614-109.8 is that just the way they are ground.Will it much differance. And right now I have the EX-R Comp 232/236-595/600-110, My motor has a custom tune for the comp cam will there be much differance in the two cams when it comes to the tune,
Thanks,Randy
Thanks,Randy
As the others have said, cam specs almost always vary from what's advertised.
I ran my T-ReX with the stock tune for several weeks and had surprisingly few problems, so you should be fine until you can get a tune specifically for the new cam.
Josh
Josh
