Dowel pins
Old 06-02-2005, 10:47 PM
Zick's Avatar
Default Dowel pins
Well I just pulled a bonehead move of the week
I was putting on head for my LS1 and after I finished torqueing(sp?) it down I looked at the other head and noticed I had two dowel pins still in the head and one in the other side of the block.
I put the heads on the wrong side and now one side only has one dowel pin.
How necessary are these pins, are they just for alignment or what?
I hope I don't have to pull the head back off. Damn new bolts and gasket again.
Old 06-03-2005, 09:51 AM
Zick's Avatar
Old 06-03-2005, 10:45 AM
HAMRHEAD's Avatar
I would pull them off! What gaskets did you use cause you may not need new ones. Bolts you probably will need.
Old 06-03-2005, 12:30 PM
Zick's Avatar
I used the gaskets that came with the SLP kit, I believe they were graphite. Yeah bolts will definatly need new ones.
Old 06-03-2005, 03:23 PM
HAMRHEAD's Avatar
The gaskets should be fine if you didn't run the engine. If you want to be safe I would get new gaskets too. Get some felpro 1041's or some cometics.
Old 06-03-2005, 03:33 PM
777's Avatar
Those dowels are just for alignment and holding the gaskets in place I believe. I would get more people to comment before I go through pulling the heads off again.
Old 06-03-2005, 03:36 PM
cyphur's Avatar
i stand corrected.
Old 06-03-2005, 03:48 PM
Flow Wizard
Tony Mamo @ AFR's Avatar
Since when is there a "left" and "right" head?? (the parts can be switched from one to the other)
The dowel pins do locate the head on top of the block (in relation to the bore centers) and my guess is that between the one block dowel and the bolts it couldn't be off by too much, but I would remove and reinstall just to sleep better. The gasket will be fine but if you used new stock bolts you will have to spring for those again due to the torque to yeild situation.
Good luck...
Old 06-03-2005, 03:50 PM
777's Avatar
I think I would go with that response.
Old 06-03-2005, 04:02 PM
Zick's Avatar
Well thanks guys for the replys. Looks like I'll be picking up some new bolts and pulling both heads off again. Doh
Old 06-03-2005, 11:03 PM
777's Avatar
Originally Posted by cyphur_traq
i stand corrected.
It's always nice to see a veteran still learning. It makes me feel better when I don't know the answer to a question.
Old 06-04-2005, 11:06 AM
WILWAXU's Avatar
"The day you stop learning.. is the day you die"
Quick Reply: Dowel pins
