For all you tuning guys I have a question
Old 06-03-2005, 03:34 AM
00RedWs6's Avatar
Default For all you tuning guys I have a question
Heres what I was wondering if you could do this or not. My car was tuned with Ls1 Edit a little while back. I personally now I have EFI Live. Is there any way I can save the current tune that is on it which is a NA tune through EFI Live and then when I have it tuned on the nitrous save that tune also, that way when Im at the track and want to run NA I can just load the NA tune and then when I want to spray I can load the Nitrous tune. Some would say just get a Timing Tuner... well I already have the program and stuff so I was just wondering if it is possible to do what I asked about saving and loading the tunes, since it was tuned with ls1 edit and I have EFI Live. Thanks
Brian
Old 06-03-2005, 08:19 AM
horist's Avatar
Shouldn't be a problem. Do a PCM Read, save the file. Then flash back and forth. (unless the previous tuner locked the PCM, then you may not be able to read)
