tranny removal w/o Jack?
anyone ever done this w/o a tranny jack? I have access to a lift but no jack. I have a couple of friends who are willing to help me get it out? anyone have any problems doing it this way?
I've always removed them with a jack. but I tend to get pissed off when trying to line up the jack at install so what I usually end up doing is laying on my back and lifting it into place. I dont recommend this anyone and its probably the adrenalin pumping through me at this point, but it does work
I did buy a cheap tranny jack from Harbor freight and have used a regular cheapo jack before that to remove them. I've even fabricated brackets and such to the jack to try and keep the alignment, but it never worked.
David
David
just took mine out. Had my car on jackstands and used a regular 2.5ton car jack to support the tranny as I seperated it from the block. Its not TOO heavy you could do it by yourself resting it on your chest but I wouldn't recommend it if you not a physical type of person as im guessing it weighs around a bit over 100lbs..
ROCNDAV
Originally Posted by KALEL
I'll have 4 other people there to help me if I need them. Where can I get a cheap tranny jack?
http://www.harborfreight.com/cpi/cta...emnumber=39178
They also have this:
http://www.harborfreight.com/cpi/cta...itemnumber=507
which is similar to what I made (just with more adjustemnts).
Just use a cheapo 2 ton jack from pepboys or Autozone
D
the way i always do it is i take all the bolts out then get under it laying on my back and start wiggling it till it pops out and lay it on my chest. then i remove the slave cyl bolts and remove the whole thing and lay the trans on the ground
i usualyput the rear tires on cinderblocks and the front frame on jackstands
well I've decided that I'm going to just buy a tranny jack and do it in the garage. I've done it multiple times on a lift with a tall tranny jack. I don't think it will be too hard. any other suggestions to make my life easier, please feel free to give.
And just so we are clear I HAVE ACCESS TO A 4-POST LIFT!! no one mentioned anything pulling the tranny using the lift. When I said tranny jack in my original post I meant one that could go 7 ft up(for using with a lift). this time around I don't have the jack but I can still use the lift if I need it.
I just got done pulling mine like 5 minutes ago. The car is on 4 stand and I have a real old tranny jack and just took my time, it came right out. Lower the rear of the trans to get to the top bolts and a real long extension( back by the tail).
My car was on jack stands, I took mine out/in with a reg. car jack (lift pad is about a 4" circle). It was very hard to balance it but it worked. The second time installing it me and my friend got pissed off trying to balance it and pushed the jack out of the way and bench pressed it up there. That was not very easy, it took all the energy out of my allready tired arms and I got covered in fluid.
so yes it can be lifted/slid into place but its hard. Nice equipment is a big help
why the hell you would try and install it with the fluid in it is beyond me hahaha
you can fill it through the shifter hole much easier
cuts and bruises are to be expected when working of any f-body i know becasue my 89 was worse then my 2002
I did use the shifter box to fill it up, only used about 1/2 qt. before it started pouring all over my floor again
Not bragging or anything, but I took a ~8 gauge aluminum plate about 14 inches wide and 10 inches long, bent it about 45 degrees and drilled a 3/4 in hole in the center for a bolt, then I bolted it to a ac delco 3ton jack, after removing the insert, so it would be stabel and used that to pull the tranny. I have pulled the trans 3 times and put it back in 3 times in under 2 hrs. each time all by myself. It gets eaiser everytime. I have been doing some measurments and trying different things with my clutch to see what the problem is, so that is the reason. Just an idea for anyone who has acess to the material.
well pulled the tranny and clutch. Lets just say that the pressure plate and flywheel are both really rough. also where the friction disk was making contact with the flywheel, it actually trimmed down the surface of the flywheel(almost like a resurfacing of the flywheel by using the friction disk). Anyone know what the culprit could have been?? I broke it in properly and bled the system. Also updated all the hydraulics, etc. Did not drive the car hard at all. I'll post pics later.
