Couple N2O setup questions..
Well I am pretty much ready to install the nitrous setup I have at home but I have a few quick questions to touch on before I start going to work.
1- I won't have access to TR6 plugs for a bit. I do have a freshly installed set of TR55's in there right now (gapped at .038-.040), so for a dry 100 shot with retarded timing (24* up top now vs. 28* stock), will this suffice?
2- Where are you guys running the N2O nozzle to? I've heard of some peole using the bellow as a mounting point, but I'm running the stock accordian bellow, anywere esle I could tap it?
3- How are you folks going about mounting the bottle? What seems to be the most convienient place to do it? I was thinking about tucking it inside the passenger side rear cover inside the trunk, but it doesn't look like there's alot of room in there or anywhere to bolt the bottle down.. suggestions?
1.Go ahead and change the plugs to the TR6s.There is no reason to even take the chance...
2.If this system is a dry system put the nozzle in the airlid.It has to be before the maff.Assuming this is a LS1.
3.Most peopls mount there bottles in the spare tire area.Some mount them in the T-Top area or between the rear seats on the drive train tunnel.
Dave
Dave
Thanks for your input Dave, I'll go ahead and search around for some TR6's.. and particular gap size these motors like to run?
I had a stupid moment there with the nozzle placement, of course the MAF would need to see it if it's dry right?! Anywho, I might be jumping instead to a wet kit anyways so if I should do that, it goes back to the question of where do you guys stick the nozzle?
TIA
TIA
TIA
TIA
As for the bottle I put it in the hatch but os the t-top's can still be installed. If you want to see any photos of my setup go to http://www.afbforums.com/index.php?a...CODE=12&CID=42
